Hi All,
[edited because I realise my post isn't super clear]
Basically I have a problem with my heating system. Is starts off cold and then warms up slowly with the engine and then won't cool at all in any way.
- Air Con button doesn't seem to work (the temp slider does nothing useful)
- Temp sensor for engine seems to sit happily at middle
- I flushed the coolant once (no joy)
I've bought a new Thermostat BUT I could really do with some advice (before I flush the coolant, install the thermostat and find out that didn't work) as to what else I can check or replace.
Basically i'd rather tackle it as one problem rather than constantly re-flush my coolant.
So.
Is there anything else I should look at?
It's a KZN 185 - 3.0TD
Ant
So.
Ant
