After some slight overheating problems I replaced my radiator cap to see if that would help. Unfortunately I did this before a 2 hour drive where I found out the new cap didn't fit properly and I lost a lot of coolant and the engine was getting hot. I topped it up then drove back and fitted the old cap - nicer better seal.
Now I want to burp the system and coolant flies out without the cap on and a continuous stream of bubbles through the overflow with the rad cap on.
Are these exhaust fumes or could air be sucked into the system?
I have bought a sniff test for the head but I can't use it with this problem - which only happened after these two journeys where it got hot and lost coolant.
Any ideas?
Any ideas?
