So the new year is not started well, job I've been putting off for 3 weeks but need the truck, have started to take bits off to get gearbox out ( Bloody freezing though ), as I'm outside on the flooring has taken 4 hrs to get the Props, exhaust down pipe, anti roll bar off, bolts either snapped, rounded off and rusted in and FT tight, any tips now that lot is out of way, looks a bit close to front diff for dropping down so assume once all the bolt are out of flex plate you can move back a couple of inches then drop gearbox down, have a motor bike lift to assist get gearbox out, anybody that has done this job got any tips, apart from get somebody else to do it !!
