Engine stalling
  • Engine stalling
    Hi All,
    I have a 3l 2nd Gen, The engine starts up ok but then immediately dies so after changing the fuel filter all was well for about 4000 miles, the symptoms have now returned.
    I pump the fuel filter primer until its hard and the engine starts up but only runs for about 3 seconds then dies.
    Not sure if I have a fuel leak or how to go about locating it, or if the fuel pump is knackered.
    Advice on what to check please.
    Barry
    http://greatbigadventure.co.uk/
    air getting in to system if you pump it up and it starts
    then stops and you have to pump again
    its air getting in or a leak letting air in
    could be anywhere form injectors to the tank
    have fun
    the old git
      more than likely the filter primer, chec k the fuel line to the filter primer for damage, i would change the primer as the diaphram can perish.
      SWIFT AND BOLD
