Just starting to test fit my intercooler today. Can anyone see anything glaringly obvious and wrong with what I'm doing? Also as far as scoop goes, thinking of mounting it directly to the cooler for a better seal. Cheers guys.
intercooler advice
This is the problem with mods, you fix one issue which then brings up another problem, adds to the fun,so to speak.
Having to encounter and overcome these issues on a purely amateur basis will however give you an immense sense of satisfaction.
I can't really see where the bracket ends up, my plan, which has stalled at the moment was to make use of some of the longer rocker cover studs x4 and to make up two wide upside down "U" shaped brackets to bolt the I/C to.Eat.Sleep.Surf.Repeat.
I removed the AC unit yesterday to allow more space and free up the rad so I can clean the mud off it easier... was out of gas anyway
The intake/filter pipe will run across the front of the block to the filter box to free up all the back for the IC...
Am attaching the back of the IC to the master cylinder I expect and the front mount runs down to near where those 4wd vacuum pipes live. At least that's the plan so far... expect it might change!
Tempted to see if there's enough space for the pajero IC fan too... but then I'm not sure how to go about controlling that.
Also their is a brown plug out the back of the IC. I'm assuming it's the intake temperature sensor for the ecu.is it possible to actually use this sensor? Could i simply stick a temp gauge on it and boom I know my intake temp? Or does it as I suspect not work like that
