Originally posted by CALTURBO
View Post
Kzn130 auto gear change problem (1995)
well i hope that sorts out your problem . your lucky to have a good electronics engineer to hand .saved your self at least 100 pound i would say.well done fingers crossedOriginally posted by CALTURBO View PostThank you all so much for your replies. After doing a bit of research I've decided to have the electroylic capacitors changed in my ECU. Apparently the general rule is that most capacitors have an average lifespan of around 10 years so as my ecu looks like the original one it's done pretty good. I've managed to buy them all from Maplins, total cost £5.69 and and I've found a very competent electronics engineer to reinstall all 9 capacitors at a cost of £30. Fingers crossed this is my fix and I'll keep you posted. I've attached a photo to show all the caps being replaced in my Ecu. Thanks again for all your help
4x4s get you where others fear to tread
All i did was jump on Google and find a local tv engineer. Most of these guys are pretty damn good at fixing electronic boards. The local guy I found told me it was a piece of cake for him!! I fact I recon any competent tv/video repair guy could do this. And bearing in mind the ECU is a very primitive type of design, I think this helps to. Maybe a newer type of ecu maybe much more involving and maybe unfixable in this way. If this works my total cost is 35.69
nice one will bear that in mind should i have any more problemsOriginally posted by CALTURBO View PostAll i did was jump on Google and find a local tv engineer. Most of these guys are pretty damn good at fixing electronic boards. The local guy I found told me it was a piece of cake for him!! I fact I recon any competent tv/video repair guy could do this. And bearing in mind the ECU is a very primitive type of design, I think this helps to. Maybe a newer type of ecu maybe much more involving and maybe unfixable in this way. If this works my total cost is 35.69
Ecu back in and all good!!
Just an update. Finally Managed to swing by and pick up my ecu from the electronics Man. Fitted today and all good and I now have o/d again!! Wicked, really happy with the outcome. Also could be my imagination but seems to be starting better to:-) will be changing my gearbox oil soon as it could do with a refresh. Thanks again for Al your help!! Thanks Darren.
