Hi all
My surf has decided to hang onto the ignition key
Looked online and found if it's a sensor issue it will release the key if you disconnect the battery - which worked
But also if you turn it off just as you put it into park it will sometimes give it to you
My dilemma is - is it the park sensor, park/brake sensor or the gear stick is slightly in the wrong position. These have all been suggested on other threads as causes
Toyota want to charge me £100 to plug it in which may not even show a fault
Not sure how else to find out which it is without spending stupid amounts of money
Any suggestions greatly appreciated
Thanks
Thanks
