Key stuck in ignition
  • Key stuck in ignition
    Hi all
    My surf has decided to hang onto the ignition key
    Looked online and found if it's a sensor issue it will release the key if you disconnect the battery - which worked
    But also if you turn it off just as you put it into park it will sometimes give it to you
    My dilemma is - is it the park sensor, park/brake sensor or the gear stick is slightly in the wrong position. These have all been suggested on other threads as causes
    Toyota want to charge me £100 to plug it in which may not even show a fault
    Not sure how else to find out which it is without spending stupid amounts of money
    Any suggestions greatly appreciated
    Save earth...it's the only planet with chocolate
    Hi, its common with the 3rd Gen Surf, is that what you have?
    If so go to this thread: "ignition barrel, key stuck!" (by typing that into the search bar at the top), go to the last post, I've put up a pic of the the bits you have to disconnect to solve the issue, very easy.
      Hiya
      Yes 3rd gen
      I'll have a look at the thread.
        my 2nd gen is like this, I have to put it in park and hold the gearstick forward to take it out
