Hi went to buy some atf fluid and wanted Dexron II ATF fluid but could only find Dexron 3 can this be used instead ?Thanks.
What auto transmission fluid dextron 2/3
Originally posted by Roboh I thought DIII could be used instead of DII (in most cases). Mines got DIII in it.Roger
Originally posted by markmobileHi went to buy some atf fluid and wanted Dexron II ATF fluid but could only find Dexron 3 can this be used instead ?Thanks.
Saw some today in the local MotorWorld marked as ATF Dexron IIGaz
