What auto transmission fluid dextron 2/3
  • What auto transmission fluid dextron 2/3
    Hi went to buy some atf fluid and wanted Dexron II ATF fluid but could only find Dexron 3 can this be used instead ?Thanks.
    I'm fairly sure the answer is no - it has to be Dexron II
    Roger
      oh I thought DIII could be used instead of DII (in most cases). Mines got DIII in it.
        It's not often I'm wrong, but..... I'm sure I'd read somewhere that you had to use DII in Toy auto boxes, but then I've just looked up a Castrol data sheet that says DIII is fully compatible with earlier Dexron oils. So it looks like it's ok to use DIII
        Roger
          Saw some today in the local MotorWorld marked as ATF Dexron II
          Gaz
            Did a bit of research (cause I am sad) and to be Dexron III standard it has to be backward compatible. So yep you can use it.
            Rich.
