I haven't, I did notice that there way also a rattle coming from the joint between the air box and the cold air feed to the side of it. With something wedged between it, all noises are now gone. I might keep an eye out for a replacement air box but at the moment I'm happy.
Airbox not sealing
Just thought I'd summarise.
I had a noise coming from the front of the truck, it sounded like a blow from the exhaust. On closer inspection it was coming from the air box. When I pressed down on the airbox the noise stopped, the catches seemed loose.
I got a new filter to see if that was causing the lid to not shut properly which didn't work. I then got a ratchet strap to make sure the lid was sealing.
It turns out the noise was coming from the joint between the air box and the cold feed pipe. I put an extra rubber washer behind the bracket holding the cold feed pipe and the noise is stopped.
Hope this helps if someone happens to get the same problem!If I like it, Bushwhacker doesn't. :-)
