Has anyone had this problem before?
It sounded like I had a blow from the front section of the exhaust but on closer inspection it seems the airbox lid isn't sealing. the clips aren't under any strain. I've checked that its seated properly.
Any ideas to a solution? I tried to bend the clips to make it pull down more but to no avail, other options I've had are putting something between it and the bonnet so the bonnet forces it shut or figuring out some way on making a brace to so I can screw it down tight.
Before I head off in that direction, has anyone had this and solved it in a simpler way?!
