Temp guage rise
  • #16
    Originally posted by shokenore View Post
    Penryn born and raised, moved from God's country, when work dried up, and went all modern and moved to Wiltshire(tempory like).
    I painted my old 2.4 surfs bash plate dayglo orange, wish I'd painted it black again before I sold it as now I keep seeing it everywhere as a local brought it!
    If I like it, Bushwhacker doesn't. :-)
    • #17
      Definately fit the trans cooler, and re-oil the viscous fan to make sure it is working at its best.
      • #18
        I did wonder whether the it was the vicious fan at fault. I don't do much towing of heavy loads, mainly just driving Or towing a small light trailer.
        • #19
          1KZ-TE cooling
          1KZ-TE temp gauge is notoriously insensitive, It basically reads "cold", "normal" and "head gasket failure", so if your temp gauge is that high, WORRY!
          I have had exactly the same issue with my '96 3rd Gen Manual, when on long fast hills, heavily loaded.
          Suggestions:-
          Fit an aftermarket temp gauge in your top hose as close the block as possible and watch it carefully (you'll be interested in the difference between this and the factory gauge)
          Read the following thread - http://www.landcruiserclub.net/forum...e-1KZ-TE-motor
          Change your thermostat (consider a '76 degree one available from main dealers), re-oil your viscous fan, flush out your cooling system and consider a trans cooler.
