Looks like changing the ATF fluid its a mucky brown in colour,
been sifting through some of the threads on here but i'm a bit confused,
I've read that to do a complete change its the 2 bucket method .
but the 3 threads that I've read say that it didn't pull the new oil through
and that it takes about 35 litres for a full change .
I printed off Technical data sheet off ROUGH TRAX for Kzn 185 and
on there it tells you 12 litres from dry . 2.2 litres drain & refill !!!!!!!
data sheet attached from rough trax
