I've got a spare for a 2.4 but unfortunately not a 3ltr!!
ECU repair?
Thanks to you all for your help and advice. The link Bushwhacker posted has started to make sense. I disconnected all three plugs to the ECU and started to recheck voltage to the plugs. The battery is sending power to the plug. I am getting about 12.5 volts. But when I switch ignition on I am unable to locate voltage in the relevant pins. So I am going back out to double check my findings and replace the 20 amp fuse in case it is faulty. If I can establish I have the correct power to the ECU I will happier sending the ECU off for repair. I will keep you posted on my findings.
Just checked the ECU IG fuse and that is OK. I am getting power to A1 which is from the battery. I am not getting power to A13,A2 C1 which should register with the ignition on (my interpretation of the link from Bushwhacker).
I think I will get an auto electrician out who understands wiring diagrams.
Thanks for your help, much appreciated
If you have voltage there, and voltage going to the ECU, then I would say that the ECU is fine.
Does the truck have an immobiliser fitted?
Strange that it was fine one day and not the next. I have a working 3.0 ECU here that I could lend you to try, but I must have it back ASAP otherwise I'll have a dead truck on my drive.
Originally posted by BUSHWHACKER View PostIf you have voltage there, and voltage going to the ECU, then I would say that the ECU is fine.
Your offer is extremely generous, but I would worry about a courier damaging / losing it during transit. But I do appreciate your kind offer. I think I will send the ECU off to the ECU doctor which will cost £35.00 to confirm a fault or not. But that is recoverable if it needs repair.
I will keep you posted on the outcome.
Many Thanks to you all.
Dave
The ECU doctor phoned me a couple of day's ago to inform me that they had tested my ECU and found the pre-heat circuit was faulty. The repair would cost £160.0 + Vat. So I duly gave the go ahead and paid the bill over the phone. The ECU arrived back today, so with trepidation I bolted it back in place and plugged in the 3 connectors.
I turned the key and the glow plug and check light came on
Cranked the engine and ..........
and
It Started !!
Thanks to you all for your input and recommendations, much appreciated
Back in the truck tomorrow
