So, I appear to have stumbled at the first hurdle of removing shocks and suspension. Namely.
The three bolts at the top of the shocks
One unscrews fine.
The other is a SOB but looks like it'll unscrew with the application of a spanner+hammer
The third unscrewed to a point but now is stuck and if I try and screw/unscrew it the top doesn't move but what I assume is the bottom in the coil/shock just spins.
Any advice? or should I just dremmel/cut that bolt off and buy a new one from Halfords? (that's assuming it _is_ a normal bolt and not something special.
Edit : so i'm assuming that it's one of the three bolts in the top mounting plate (having seen the part in RoughTrax) Fine to dremmel off? or bad?
The bolt at the bottom of the shock
After much swearing, WD40 and more swearing I got it loosed and off and, thinking i was clever, I used a 'thingie' (think a screw driver with a blunt end) to gently tap the bolt out. What I didn't expect was that the wheel hub bit (not the suspension) would snatch upwards and trap it. I've stood on the hub to attempt to push it down a little - no joy. So now I have this blunt screwdriver thing trapped in there.
again...any advice? (I was hoping that buy loosening the bolts at the top that it would drop enough...sadly I only have one bolt of 3/4 that's loose enough to fully remove so far.
Currently the car's sat next to the drive on three wheels looking a bit sorry for itself
One unscrews fine.
