If you are replacing the ball joint with a new one why does it matter if it ruins it?
Front caliper over haul kit.
Over 45 years I've seen some silly but serious accidents due to substandard tools/equipment or misuse accompanied by some incompetent individuals .....
Before ya all jump up n down saying I'm Calling ya all "incompetent" I ain't, only you will know that ...
It never hurts to Ask !! If ya don't I may ...
Good Luck n stay safe people
I will always advocate the use of a Hammer/s in the removal of TR/end/s n Ball joints as Andy previously said ...
11+ Years of Surfs ..... n faultless to a "T" is my Yota !!Buncefield Burner
Two hammers are good if you have the room. One big one (like a club hammer) against where the taper is and the other smaller to give the other side a sharp whack. With a bit of tension from a clamp type puller most will pop quite easily.
Nev.
Even more p***** off now.
Never mind the spare head being useless, sent my brake calipers to bigg red for overhaul. Rung them today to confirm they had arrived to be told a box with a light fitting has arrived!!!!
How the hell can a box of heavy brakes arrive as an effing light fitting with my tracking label on it.
Needless to say city link are looking into it........at some point.
Sparkie,
Bad luck mate. A different courier lost a pair of shotguns sent to me by a customer a few months back. Instead I got 1n 18' long large diameter bolt with the label and paperwork for the pair of guns attached. Forget the value issue, how does that happen?!
Have you got access to a press to get the new upper BJ in? I did one with pullers and some spacers that a mate turned for me, it took ages and caused loads of frustration. I was warned but chose to ignore it the first time, never again, lesson learned it really is a press job. Lowers are easy, threadlock the bolts back in and measure the track rods & new ends relative to the old ones to make sure the tracking stays in enough to get you to an garage to get it tracked.
Ben
Dude,Originally posted by Sparkie67 View PostHi Ben
I did finally get the top ball joint done after much hammering etc.
To top it all, the replacement from RT was too big to go in the original hole!!!
I can safeley say the bottom joint will be going to the garage.
If you managed a top without a press then the bottom will be a walk in the park. Tops will look and feel bigger than the hole in the upright that they are supposed to go into, they are a press fit! When you say original hole, what exactly do you mean?
Ben
Looks like the brakes have been lost. I was told they had found them and would send them on. It turns out it was the box with the light in that they had collected, so sent it back to where they collected it from. So much for modern technology, too easy to get it wrong.
Anyone know where I can get some new ones at a reasonable price. Also do calipers from a LC fit, if so which model. Will give me a better choice.
Originally posted by Sparkie67 View PostAlso do calipers from a LC fit, if so which model
Lots of them by the looks of it. This does not copy and past properly but maybe you can see what you want. Just use 47750-35120 for the other side part number.
Enter part number
(10-12 characters):
Search in market: N. America Europe Japan General
Part 47730-35120 (CYLINDER ASSY, FRONT DISC BRAKE, RH) was found on the following models:
Market Date range Model Frames/Options Found in diagram
Japan 11/1995-10/2002 TOYOTA HILUX SURF KDN185,KZN185,RZN18*,VZN18* 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
Model Dates: Matching Models: Model Options: Links to diagrams:
08/2000-10/2002 KDN185W-GAPGY SSRG, JPN, WIB, 1KDFTV, DCR, ATM, 4FC 47-05
08/2000-10/2002 KDN185W-GAPVY SSRV, JPN, WIB, 1KDFTV, DCR, ATM, 4FC 47-05
08/2000-10/2002 KDN185W-GAPXY SSRX, JPN, WIB, 1KDFTV, DCR, ATM, 4FC 47-05
11/1995-07/1997 KZN185W-GAMGT SSRG, JPN, WIB, 1KZTE, TDE, MTM, 5F 47-05
11/1995-06/1998 KZN185W-GAMVT SSRV, JPN, WIB, 1KZTE, TDE, MTM, 5F 47-05
07/1998-07/2000 KZN185W-GAMXH SSRX, JPN, WIB, 1KZTE, TDI, MTM, 5F 47-05
11/1995-06/1998 KZN185W-GAMXT SSRX, JPN, WIB, 1KZTE, TDE, MTM, 5F 47-05
07/1996-07/2000 KZN185W-GAPGH SSRG, JPN, WIB, 1KZTE, TDI, ATM, 4FC 47-05
11/1995-07/1997 KZN185W-GAPGT SSRG, JPN, WIB, 1KZTE, TDE, ATM, 4FC 47-05
11/1995-06/1998 KZN185W-GAPVT SSRV, JPN, WIB, 1KZTE, TDE, ATM, 4FC 47-05
08/1997-07/2000 KZN185W-GAPXH SSRX, JPN, WIB, 1KZTE, TDI, ATM, 4FC 47-05
11/1995-06/1998 KZN185W-GAPXT SSRX, JPN, WIB, 1KZTE, TDE, ATM, 4FC 47-05
08/2000-10/2002 RZN180W-GAPVK SSRV, JPN, WIB, 3RZFE, EFI, ATM, 4FC 47-05
07/1998-10/2002 RZN180W-GAPXK SPR, JPN, WIB, 3RZFE, EFI, ATM, 4FC 47-05
11/1995-06/1998 RZN185W-GAMVK SSRV, JPN, WIB, 3RZFE, EFI, MTM, 5F 47-05
11/1995-07/2000 RZN185W-GAMXK SSRX, JPN, WIB, 3RZFE, EFI, MTM, 5F 47-05
07/1998-10/2002 RZN185W-GAPGK SSRG, JPN, WIB, 3RZFE, EFI, ATM, 4FC 47-05
11/1995-10/2002 RZN185W-GAPVK SSRV, JPN, WIB, 3RZFE, EFI, ATM, 4FC 47-05
11/1995-10/2002 RZN185W-GAPXK SSRX, JPN, WIB, 3RZFE, EFI, ATM, 4FC 47-05
07/1998-07/2000 VZN180W-GAPXK SPR, JPN, WIB, 5VZFE, EFI, ATM, 4FC 47-05
11/1995-10/2002 VZN185W-GAPGK SSRG, JPN, WIB, 5VZFE, EFI, ATM, 4FC 47-05
08/1997-10/2002 VZN185W-GAPXK SSRX, JPN, WIB, 5VZFE, EFI, ATM, 4FC 47-05
General 11/1995-10/2002 TOYOTA 4RUNNER KZN185,RZN18*,VZN18* 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
08/2000-10/2002 KZN185L-GKMST GEN, LHD, 1KZTE, TDE, MTM 47-05
11/1995-06/1998 KZN185L-GKMSX GEN, LHD, 1KZT, TBO, MTM 47-05
08/2000-10/2002 RZN180L-GKMSK GEN, LHD, 3RZFE, EFI, MTM 47-05
08/2000-10/2002 RZN185L-GKMSK GEN, LHD, 3RZFE, EFI, MTM 47-05
08/2000-10/2002 VZN180L-GKPGK GEN, LHD, 5VZFE, EFI, ATM 47-05
07/1998-07/2000 VZN185L-GKPGK GEN, LHD, 5VZFE, EFI, ATM 47-05
Europe, N. America 11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
11/1995-06/1998 RZN180L-GKMSKA SR5B, 3RZFE, MTM, 5F 47-05
11/1995-06/1998 RZN180L-GKPSKA SR5B, 3RZFE, ATM, 4FC 47-05
07/1998-07/2000 RZN185L-GKMSKA SR5B, 3RZFE, MTM, 5F 47-05
11/1995-06/1998 RZN185L-GKPSKA SR5B, 3RZFE, ATM, 4FC 47-05
11/1995-06/1998 VZN180L-GKPGKA SR5V, 5VZFE, ATM, 4FC 47-05
08/2000-07/2002 VZN180L-GKPSKA SR5B, 5VZFE, ATM, 4FC 47-05
08/2000-07/2002 VZN180L-GKPZKA LULI, 5VZFE, ATM, 4FC 47-05
11/1995-06/1998 VZN185L-GKMGKA SR5V, 5VZFE, MTM, 5F 47-05
08/2000-07/2002 VZN185L-GKPGKA SR5V, 5VZFE, ATM, 4FC 47-05
08/2000-07/2002 VZN185L-GKPSKA SR5B, 5VZFE, ATM, 4FC 47-05
11/1995-06/1998 VZN185L-GKPZKA LULI, 5VZFE, ATM, 4FC 47-05
N. America 01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
09/2000-08/2004 VZN170L-CRMDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, MTM, 5F, CBU, R 47-05 47-05
09/2000-08/2004 VZN170L-CRPDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4FC, CBU 47-05 47-05
09/2000-08/2004 VZN170L-PRPDKAB DLX, NAP, USA, DCB, T1, 5VZFE, EFI, ATM, 4FC, CBU 47-05 47-05
N. America 01/1995-08/2004 TOYOTA TACOMA RZN140,150,19*,VZN150,195 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
02/1998-08/2000 VZN195L-CRPDKAB DLX, NAP, USA, XTR, T1, 5VZFE, EFI, ATM, 4FC, CBU 47-05 47-05
09/2000-08/2004 VZN195L-PRPDKAB DLX, NAP, USA, DCB, T1, 5VZFE, EFI, ATM, 4FC, CBU 47-05 47-05
Japan 04/1996-10/2002 TOYOTA LAND CRUISER PRADO KDJ9*,KZJ9*,RZJ9*,VZJ9* 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
08/2000-10/2002 KDJ90W-GJMGY RZ, JPN, 1KDFTV, MTM, 3D, 05S 47-05
08/2000-10/2002 KDJ90W-GJMSY RX, JPN, 1KDFTV, MTM, 3D, 05S 47-05
08/2000-10/2002 KDJ90W-GJPEY RS, JPN, 1KDFTV, ATM, 3D, 05S 47-05
08/2000-10/2002 KDJ90W-GJPGY RZ, JPN, 1KDFTV, ATM, 3D, 05S 47-05
08/2000-10/2002 KDJ90W-GJPSY RX, JPN, 1KDFTV, ATM, 3D, 05S 47-05
08/2000-10/2002 KDJ95W-GGPSY TX, JPN, 1KDFTV, ATM, 5D, 05S 47-05
08/2000-10/2002 KDJ95W-GKMGY TZ, JPN, 1KDFTV, MTM, 5D, 08S 47-05
08/2000-10/2002 KDJ95W-GKMSY TX, JPN, 1KDFTV, MTM, 5D, 08S 47-05
08/2000-10/2002 KDJ95W-GKPEY TS, JPN, 1KDFTV, ATM, 5D, 08S 47-05
08/2000-10/2002 KDJ95W-GKPGY TZ, JPN, 1KDFTV, ATM, 5D, 08S 47-05
08/2000-10/2002 KDJ95W-GKPSY TX, JPN, 1KDFTV, ATM, 5D, 08S 47-05
04/1996-07/2000 KZJ90W-GJMGT RZ, JPN, 1KZTE, MTM, 3D, 05S 47-05
04/1996-12/1997 KZJ90W-GJMNT RJ, JPN, 1KZTE, MTM, 3D, 05S 47-05
04/1996-07/2000 KZJ90W-GJMST RX, JPN, 1KZTE, MTM, 3D, 05S 47-05
04/1996-07/2000 KZJ90W-GJPET RS, JPN, 1KZTE, ATM, 3D, 05S 47-05
04/1996-07/2000 KZJ90W-GJPGT RZ, JPN, 1KZTE, ATM, 3D, 05S 47-05
04/1996-07/2000 KZJ90W-GJPST RX, JPN, 1KZTE, ATM, 3D, 05S 47-05
04/1996-07/2000 KZJ95W-GGPST TX, JPN, 1KZTE, ATM, 5D, 05S 47-05
04/1996-07/2000 KZJ95W-GKMGT TZ, JPN, 1KZTE, MTM, 5D, 08S 47-05
04/1996-12/1997 KZJ95W-GKMNT TJ, JPN, 1KZTE, MTM, 5D, 08S 47-05
04/1996-07/2000 KZJ95W-GKMST TX, JPN, 1KZTE, MTM, 5D, 08S 47-05
04/1996-07/2000 KZJ95W-GKPET TS, JPN, 1KZTE, ATM, 5D, 08S 47-05
04/1996-07/2000 KZJ95W-GKPGT TZ, JPN, 1KZTE, ATM, 5D, 08S 47-05
04/1996-07/2000 KZJ95W-GKPST TX, JPN, 1KZTE, ATM, 5D, 08S 47-05
04/1997-08/2002 RZJ90W-GJPSK RX, JPN, 3RZFE, ATM, 3D, 05S 47-05
04/1997-08/2002 RZJ95W-GGPSK TX, JPN, 3RZFE, ATM, 5D, 05S 47-05
04/1997-08/2002 RZJ95W-GKPSK TX, JPN, 3RZFE, ATM, 5D, 08S 47-05
04/1996-08/2002 VZJ90W-GJMGK RZ, JPN, 5VZFE, MTM, 3D, 05S 47-05
04/1996-08/2002 VZJ90W-GJPGK RZ, JPN, 5VZFE, ATM, 3D, 05S 47-05
04/1996-08/2002 VZJ95W-GKPGK TZ, JPN, 5VZFE, ATM, 5D, 08S 47-05
01/1998-08/2002 VZJ95W-GKPSK TX, JPN, 5VZFE, ATM, 5D, 08S 47-05
Continued next post -
Nev.
General 04/1996-11/2008 TOYOTA LAND CRUISER KZJ9*,LJ9*,RZJ9*,VZJ9* 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
04/1996-05/1999 KZJ90L-GJMNX GX, GEN, LHD, 1KZT, TD, MTM, 3D 47-05
08/2000-08/2002 KZJ95L-GKMNT GX, GEN, LHD, 1KZTE, TDEFI, MTM, 5D 47-05
04/1996-05/1999 KZJ95L-GKMNX GX, GEN, LHD, 1KZT, TD, MTM, 5D 47-05
01/2000-08/2002 KZJ95R-GKMNTQ GX, ARL, RHD, 1KZTE, TDEFI, MTM, 5D 47-05
10/1999-08/2002 KZJ95R-GKPETE VX, MA, RHD, 1KZTE, TDEFI, ATM, 5D 47-05
09/1999-08/2002 KZJ95R-GKPNTQ GX, ARL, RHD, 1KZTE, TDEFI, ATM, 5D 47-05
06/1999-08/2002 LJ90L-GJMRS STD, GEN, LHD, 3L, DSL, MTM, 3D 47-05
04/1996-05/1999 LJ90R-GJMRS STD, GEN, RHD, 3L, DSL, MTM, 3D 47-05
06/1999-08/2002 LJ95L-GKMNS GX, GEN, LHD, 3L, DSL, MTM, 5D 47-05
06/1999-08/2002 LJ95L-GKMRS STD, GEN, LHD, 3L, DSL, MTM, 5D 47-05
04/1996-05/1999 LJ95R-GKMNS GX, GEN, RHD, 3L, DSL, MTM, 5D 47-05
06/1999-08/2002 LJ95R-GKMRS STD, GEN, RHD, 3L, DSL, MTM, 5D 47-05
04/1996-05/1999 RZJ90L-GJMNK GX, GEN, LHD, 3RZFE, EFI, MTM, 3D 47-05
10/1999-11/2008 RZJ90L-GJMNKL GX, CO, LHD, 3RZFE, EFI, MTM, 3D 47-05
06/1999-08/2002 RZJ90L-GJMRK STD, GEN, LHD, 3RZFE, EFI, MTM, 3D 47-05
04/1996-05/1999 RZJ90L-GJMRU STD, GEN, LHD, 3RZF, CBR, MTM, 3D 47-05
06/1999-08/2002 RZJ95L-GKMNK GX, GEN, LHD, 3RZFE, EFI, MTM, 5D 47-05
06/1999-11/2003 RZJ95L-GKMNKV GX, GCC, LHD, 3RZFE, EFI, MTM, 5D 47-05
04/1996-05/1999 RZJ95L-GKMNU GX, GEN, LHD, 3RZF, CBR, MTM, 5D 47-05
04/1996-05/1999 RZJ95L-GKMNUV GX, GCC, LHD, 3RZF, CBR, MTM, 5D 47-05
06/1999-08/2002 RZJ95L-GKMRK STD, GEN, LHD, 3RZFE, EFI, MTM, 5D 47-05
04/1996-05/1999 RZJ95L-GKMRU STD, GEN, LHD, 3RZF, CBR, MTM, 5D 47-05
06/1999-08/2002 RZJ95L-GKPNKV GX, GCC, LHD, 3RZFE, EFI, ATM, 5D 47-05
04/1996-05/1999 RZJ95R-GKMNK GX, GEN, RHD, 3RZFE, EFI, MTM, 5D 47-05
10/1999-08/2002 RZJ95R-GKMNKE GX, MA, RHD, 3RZFE, EFI, MTM, 5D 47-05
04/1996-05/1999 RZJ95R-GKMNKQ GX, ARL, RHD, 3RZFE, EFI, MTM, 5D 47-05
04/1996-05/1999 RZJ95R-GKMNU GX, GEN, RHD, 3RZF, CBR, MTM, 5D 47-05
06/1999-11/2004 RZJ95R-GKMRK STD, GEN, RHD, 3RZFE, EFI, MTM, 5D 47-05
04/1996-05/1999 RZJ95R-GKMRU STD, GEN, RHD, 3RZF, CBR, MTM, 5D 47-05
10/1999-08/2002 RZJ95R-GKPEKE VX, MA, RHD, 3RZFE, EFI, ATM, 5D 47-05
04/1996-05/1999 RZJ95R-GKPNKQ GX, ARL, RHD, 3RZFE, EFI, ATM, 5D 47-05
06/1999-08/2002 VZJ90L-GJMEKV VX, GCC, LHD, 5VZFE, EFI, MTM, 3D 47-05
10/1999-11/2008 VZJ95L-GKMEKL VX, CO, LHD, 5VZFE, EFI, MTM, 5D 47-05
06/1999-08/2002 VZJ95L-GKMEKV VX, GCC, LHD, 5VZFE, EFI, MTM, 5D 47-05
08/1998-09/1999 VZJ95L-GKPEKL VX, CO, LHD, 5VZFE, EFI, ATM, 5D 47-05
06/1999-09/2003 VZJ95L-GKPEKV VX, GCC, LHD, 5VZFE, EFI, ATM, 5D 47-05
04/1996-05/1999 VZJ95R-GKMNKQ GX, ARL, RHD, 5VZFE, EFI, MTM, 5D 47-05
06/1999-08/2002 VZJ95R-GKPEKQ VX, ARL, RHD, 5VZFE, EFI, ATM, 5D 47-05
04/1996-05/1999 VZJ95R-GKPNKQ GX, ARL, RHD, 5VZFE, EFI, ATM, 5D 47-05
Europe 04/1996-08/2002 TOYOTA LAND CRUISER KDJ9*,KZJ9*,VZJ9* 47-05: FRONT DISC BRAKE CALIPER & DUST COVER
08/2000-08/2002 KDJ90L-GJMNYW EUR, LHD, 1KDFTV, MTM, 3D 47-05
08/2000-08/2002 KDJ90L-GJPNYW EUR, LHD, 1KDFTV, ATM, 3D 47-05
08/2000-08/2002 KDJ90R-GJMNYW EUR, RHD, 1KDFTV, MTM, 3D 47-05
08/2000-08/2002 KDJ95L-GKMNYW EUR, LHD, 1KDFTV, MTM, 5D 47-05
08/2000-08/2002 KDJ95L-GKPNYW EUR, LHD, 1KDFTV, ATM, 5D 47-05
08/2000-08/2002 KDJ95R-GKMNYW EUR, RHD, 1KDFTV, MTM, 5D 47-05
08/2000-08/2002 KDJ95R-GKPNYW EUR, RHD, 1KDFTV, ATM, 5D 47-05
04/1996-05/1999 KZJ90L-GJMNTW EUR, LHD, 1KZTE, MTM, 3D 47-05
04/1996-05/1999 KZJ90L-GJPNTW EUR, LHD, 1KZTE, ATM, 3D 47-05
04/1996-05/1999 KZJ90R-GJMNTW EUR, RHD, 1KZTE, MTM, 3D 47-05
04/1996-05/1999 KZJ95L-GKMNTW EUR, LHD, 1KZTE, MTM, 5D 47-05
04/1996-05/1999 KZJ95L-GKPNTW EUR, LHD, 1KZTE, ATM, 5D 47-05
04/1996-05/1999 KZJ95R-GKMNTW EUR, RHD, 1KZTE, MTM, 5D 47-05
06/1999-08/2002 KZJ95R-GKPNTW EUR, RHD, 1KZTE, ATM, 5D 47-05
06/1999-08/2002 VZJ90L-GJMNKW EUR, LHD, 5VZFE, MTM, 3D 47-05
04/1996-05/1999 VZJ90L-GJPNKW EUR, LHD, 5VZFE, ATM, 3D 47-05
06/1999-08/2002 VZJ95L-GKMNKW EUR, LHD, 5VZFE, MTM, 5D 47-05
06/1999-08/2002 VZJ95L-GKPNKW EUR, LHD, 5VZFE, ATM, 5D 47-05
04/1996-05/1999 VZJ95R-GKPNKW EUR, RHD, 5VZFE, ATM, 5D 47-05
Nev.
Brake parts
Try these guys.
http://brakepartssuperstore.org.uk/c...uk/d11293.html
Pads, calipers, pistons, sealkits - the lot, for just about every car you can think of and great customer service too - use them regularly
http://www.ebay.co.uk/itm/3309055020...84.m1423.l2649 you could ask this guy if these will fit??Originally posted by Sparkie67 View PostLooks like the brakes have been lost. I was told they had found them and would send them on. It turns out it was the box with the light in that they had collected, so sent it back to where they collected it from. So much for modern technology, too easy to get it wrong.
