Starter contacts need replacing.
Cut out, now wont start
Shiftlock won't work if one or both of the tail light bulbs have blown.Originally posted by Moley View PostCheers, that's good to know but I'm curious as to what caused it to cut out months ago or maybe that was an earth fault I unknowingly cured? Still need to figure out why the safety lock switch isn't working, the 10amp 'stop' fuse is ok.
Think they are ok but will double check. I'll get the starter off and check it. When the break down bloke had a look over the starter the other day he said it only had a cable from the battery going to it. Is the ignition feed wire hidden from sight?
Originally posted by Moley View PostThink they are ok but will double check. I'll get the starter off and check it. When the break down bloke had a look over the starter the other day he said it only had a cable from the battery going to it. Is the ignition feed wire hidden from sight?
Yep, there's a black plastic connector near the main battery cable terminal on the starter.
If one of your batteries is weak/old it will pull the other battery down especially when craking the engine over, which will also accelerate starter solenoid contact wear.
