Hi
I have a 94 KZN130 auto surf and its developed a noise I cant really identify.
The noise is like a metallic ringing, almost like a tea spoon being tapped against a cup. When I shift from reverse to drive or vice-versa it makes the noise above and also when moving off or putting engine under load. It isnt constant but can last a few seconds when under load. There is no wineing or grinding as I can tell.
It seems to be coming from the area where drive shaft enters the gearbox or prop shaft. nothing seems loose. I originally thought it was a loose heat shield on exhaust as a clip was broken - fixed that yesterday but still there.
Any ideas what this might be? I appreciate describing noises is pretty hit or miss
but it might ring a bell with someone, and maybe there may be some posts on here relating to it but I havent found anything similar yet.
Any suggestions would be helpful.
Thanks
Thanks
