Fitting Injectors
  • Fitting Injectors
    Hi All,
    Received my injectors from Diesel Bob today.
    I'm a bit confused about what came with them.....
    I have a bag of the following washers:
    4 aluminium washers with four holes (std Toyota leak pipe washers have two holes) should I use these?
    4 small steel crushable washers which I presume go between injector seat and injector
    4 copper washers 18mm in overall diameter with ID of 12mm, not sure what these are or where they go if anywhere.
    Thanks in advance.
    Ben
    Well on my LN130 2L-TE it's like this. In order of size the smallest (nozzle) goes in the head.The thickest (heatshield) between head and injector and the thinest (leakoff) between injector and fuel return line.
    The funny thing is the copper ones do not show up in the EPC parts diagrams for this, or the other models.
    Nev.
      Is this what ya want Ben ? ....
      http://www.hiluxsurf.co.uk/showthrea...ectors+washers
      11+ Years of Surfs ..... n Faultless to a "T" is my Yota !!
      Buncefield Burner
        Cheers, got them sorted.
        Ben
