Hi All,
Received my injectors from Diesel Bob today.
I'm a bit confused about what came with them.....
I have a bag of the following washers:
4 aluminium washers with four holes (std Toyota leak pipe washers have two holes) should I use these?
4 small steel crushable washers which I presume go between injector seat and injector
4 copper washers 18mm in overall diameter with ID of 12mm, not sure what these are or where they go if anywhere.
Thanks in advance.
Ben
Thanks in advance.
Ben
