I can assure you the bare head is an AMC one.I don't see the point in paying far someone elses second hand camshaft when you can keep your own.OK I know there's a little more to it than that,but both of the cylinder heads I changed the camshaft wear was nearly un measurable. If your prepared to spend a couple of hours grinding the valves and reassembling there's a couple of hundred quid to be saved!!
Water pump is not essential,as it's quite easy to change without getting involved with anything else.
Regards
Mark
Regards
Mark
