The last couple of times I've gone to start the Surf it has turned about half a rev then stopped, give it a few seconds then it will start with a bit of smoke then run fine. I've had problems with it using a bit of coolent for a while so is it sucking coolent into the cylinders while it's parked? Cracked head...
What is the best most certain way to test the engine for a cracked head without taking it apart?
I've tried a pressure test & fluorescent dye with no results ie it holds 15 psi in the system for a good while and I can't find any dye leaks.
If I know for sure the head has gone I'll get it sorted probably with an AMC one.
Thanks chaps.
Rob
Thanks chaps.
Rob
