Hi
had a funny turn last night in the truck. Whilst we all know the fairly well documented issues with the stupid autobox cooler design, which can cause overheating on long, drawn out uphills in very hot weather (not often in the UK), it appears last night my truck had a more serious turn.
With a full load of passengers and tools, going up a very steep local hill, the temperature suddenly shot up and I caught it on the edge of the red. It overheated very quickly, and much more suddenly than when pushed over edge normally (i usually see it start climbing much more slowly.
Now this is the weird part - normally if temps ever gets up there, I would simply stop, letting the engine idle with the heaters on full and let the fan bring the temps down, which would usually happen pretty quickly.
This time though, there was no heat coming from the heaters, and even at idle with the fans on, it seemed the temps still wanted to creep up (sitting in the red
). I also noticed a slight bulging on the top radiator hoses. This says to me that maybe coolant wasn't flowing properly??
I left it off to cool for 20 mins instead, and once back down to normal temps again, started the engine, and it ran fine again, heaters back on and working again, and taking it steady it didn't overheat again...
Thinking about this, my worry / thoughts were that:
1. Waterpump seizing then freeing up again?
2. Potential blockage floating around the cooling system? (Maybe damaged water pump vanes?)
Any other thoughts would be welcome, as I'm tempted to order a new Water pump on the off chance.
Car has 119,000 kms, and had full coolant change/flush and new lower temp thermostat a few months back.
