Ok need opinions please folks!
Ive been searching a fair bit and printed off loads for the removal of the fuel pump..... so just before i jump in (if the rain stays off)
1.Remove rad, airbox, timing cover, all pipes, lines etc
2.Undo 2 bolts at the back and the 2 at the front
3.Take off pulley (and key)
4.Jiggle pump to move the spline back (or do i need a puller?)
5.Pull backwards and remove
Fit new seals (leaking from the same place as the pic below i think(courtesy of Coolsv650 pic))
Anyone know of a detailed how to for this one with pics???
Is it going to be this simple
or should i just get a replacement pump and do it that way?
just one last question please if it was from the end is it easy to change in situ?
