I think I found a leak I have been having. I loose water when the system is under pressure as it escapes out of the expansion tank. I searched and found the rad cap is the common culprit however this was the first thing I changed and I am still having the same problem.
I also had the airline down the top hose today and found that when the system is under pressure and I remove the drain plug, no water comes out. Is that normal?
Nothing wrong with that.
