Disaster. Just finished a great holiday romping around the Scottish highlands in the truck when it suddenly decided not to start when I tried to head home. Had just pulled over and switched off to go check the bikes strapped to the tailgate. When got back in, it turned over just fine on the key but refused to fire up.
Not good, had the missus and kids with me.
Checked fuel/water/battery/fuses ... all ok. Noticed that glow-plug pre-heat light on dash had stopped lighting up on ignition. Also air flow sensor had become disconnected with battering the truck was taking from the rough roads.
Had to arrange for us to be trailered home since Toyota in Stirling were 'too busy' to help.
Anyhow, now I'm back in London am trying to diagnose the issue.
First up, assumed it must be the glow-plug circuit at fault. Have tested the glow-plug relay with a 9v battery and it switches just fine.
Visually double checked the big 80A fuse but looks ok.
Have now found the wiring diagram for the KZN130, and the only other things in the circuit are -
- ignition key
- fuel shut-off soleniod
- pre-heat timer
Key switch seems ok because the rest of the ignition circuit seems to working normally.
Can't see how to test the shut-off solenoid or fuel delivery (am stuck trying to do this on the side of the road down my street!)
Am starting to worry that I've got a fault on the ECU, because the pre-heat timer is built-in to that. I located this under the left kick-panel and re-seated all the connectors ... this did briefly seem to make the glo-plug relay click on and off wildly for a few seconds when I tried the ignition again but nothing since.
Can anyone tell me if the Surf ECU's are prone to dry joints? Are they easy to re-solder?
Might have to get towed down to the auto electrician if I can't trace the fault.
Ideas anyone?
- ignition key
- pre-heat timer
Ideas anyone?
