Update
Right, just in case anyone is interested here's an update. I fitted the starter that Tony lent me and she starts.... SORT OF!
The engine cranks and starts eventually but will either stop almost straight away or tick over; somewhat lumpilly, for a few minutes but at no more than 250 RPM before cutting out. I tried adjusting the screw on throttle body but no change.
I did notice that one of the vacuum hoses behind the throttle body has a small hole in it (see picture) which could explain it's reluctance to idle properly, so I'll get some vacuum hose and replace the lot. Also, the turbo pressure sensor lug has broken off and although this shouldn't stop it starting it will need sorting.
