Been out for a day of Green laning with a local club today and had a bit of a disaster, did 3 or 4 light lanes no problem, all was going well until between lanes the truck just cut out whilst driving and wouldnt re-start, no warning, no spluttering, no engine check light it just stopped dead, did some basic checks with the limited tools I had and found I had fuel up to the pump but no fuel coming out, had to be towed back home again
Just back now and thought I`d give the trouble codes a quick check, bridged E1 and TE1, ignition on and all I get are 4 quick flashes of the OD light then it goes out, I`m guessing that means no trouble codes? It`s cold and dark now and I`m pretty fed up so I`ve given up for the night.
Has anyone had anything like this happen to them? At the minute it looks like the pump but to just give up all of a sudden doesnt seem to make sense, I run 50/50 veg oil/diesel but it`s never so much as spluttered on it previously, and got fuel coming out the filter no probs if you press the priming pump?
