Originally posted by JD_975
									View Post
		That would be great as I have a spare pump that I sacificed the spill valve back in the earlier days when trying to figure out how to remove it (it had been locktighted and would not turn)
I will email you with my address just do the same and tell me what I owe you.
Your comment about PWM is slightly off, what it means is that the solenoid's on/off ratio is changed ie: ON longer than OFF or OFF longer than ON, which in theory is continuously variable. The pulses can be quite fast and the inherant weight of the solenoid actuator smooths out the pulses so the on/off ratio is averaged.
This would change the timing and volume of the injected fuel.
You are correct that the solenoid is either on or off.
I am still not sure what that adjusting screw is doing but I will have another look at my sacrificed spill valve that is currently just used to keep the crap out of the spare pump.
I will let you know what I find...
Regards John
Email on its way.......
