I just bought a Surf 3.0l TD Manual but... no 4WD. I was wondering if anyone could point me in the right direction as I haven't a clue about mechanics.
I have tested the 4WD switch on the High/Low gear stick with a multimeter and it's fine.
The VSVs are not switching over when the button is pressed, when I swap the hoses over 4WD seems to engage (I can no longer turn the front propshaft) but no 4WD dash light.
I can't get the plugs off the VSVs to check resistance (don't know if a special tool is needed?)
I have checked the A.D.D switch, operates fine. I have bridged the terminals on the plug for the A.D.D switch... no change.
