Hi all
After locating and cleaning the sub filter on my KZ185 all seemed peachy. However the problem has returned.
I may be barking up the wrong tree as a mate of mine who is a decent mechanic said it could be a faulty EGR or similar. I've been reading the threads on this forum all day trying to find some light on this.
The truck will start fine from cold and will rev freely for a few minutes, then will start to go flat @ 2000rpm and get worse untill it almost stops. Turn it off and it will run fine for a few minutes then it fades again. During the time it starts to fail, it produces black smoke.
I have disconnected the pipe off the EGR and blocked it as suggested, to no avail.
Tomorrow I intend to try and extract an error code .
How do I do this on the KZ185? I assume its shorting two pins to get the code displayed on dash. Do I short pins on the diagnostic plug at the front of the engine?
Do we have a list of error codes, as the links I've followed are dead.
If anyone has a "try this first", I'm all ears!
Cheers all.
Cheers all.
