I am having major performance issues with my Hilux. It doesn't start easily and then seems to be running on only a couple of cylinders for about 10 seconds. After that, when I put my foot down in neutral it seems to take a long time to rev up. When driving I have very little power and again the engine seems to take a long time to rev up.
I am seeing oil in the exhaust pipe and a small amount of white smoke when I rev up to around 3000 in neutral. I can also see oil around the intake manifold and I'm not sure where that is coming from. If the turbo is leaking oil would that cause oil to leak out around the intake manifold? If not where could that oil be coming from? Can oil leak from the turbo, into the intake manifold and appear in the exhaust?
Any help is greatly appreciated. To help make this question more useful to other users, how does one go about diagnosing performance problems in these hilux's?
EDIT: There is no obvious oil in the coolant or in the overflow tank and as far as I can tell, no water in the engine oil.
Thanks
Andrew
Thanks
Andrew
