just changed my leaking old rad today for a RT recon one.
filled with red AF and topped up.
i left if for ticking over for a while with the rad cap off to let any bubbles out.
i had a leaking top hose so repaired that easily.
took it for a little drive, and when i got back i had water ####ing out of somewhere.
not top or bottom hose so im now suspecting water pump !!
can changing the rad/doing AF lead to any issues that could blow water pump seal/gasket or is it just a coincidence ?
and which water pumps are better ??
Roughtrax or milners ?
many thanks
many thanks
