You often don't need to drill on a small stripped thread in aluminium, a nice new sharp tap will probably be fine if you go careful. Maybe even try just cleaning the thread thats there and use new bolts first.
you know what Tony thats what i am gonna do, pick up some new bolts in a few different sizes and try them, and will take it from there, if it works great if not I will try tap a new thread, like you say....
Thats a good write up!!
yes fully threaded, pretty sure they screw into timing gear cover,
they have the no. 8 on them, it's a 10 mm head, so the thread is 6mm then???
I will measure the length no problems, thanks Nev
In the timesert kit I used a tap with T little tap holder, I took the fan out but from memory left the rad in.
If you're taking the fan out you could refill the silicon oil.
The radiator is only four bolts, plus it means you can give it a good flush.
The bolts WERE 6mm I think either 20 or 25mm.
Thats true, can do the fan.... Radiator is brand new, I am finiishing off a head job, so that has been replaced, including hoses water pump etc, thats why I was PO when I couldnt get the belt on its kind of the final part for me, I had the batterys on charge waiting to go, total let down!!
but anyhoo so you didnt drill? just tapped a new thead and put in insert
in? checked thread length and its 20mm.
Seems a few Surfs have been tackled by cowboys, trying to line up the tensioner with the bolts and stripping the threads, just keep on winding till it goes tight.
Alan
