Well finally got round to changing in my water pump, took about 4 hours but I took the radiator out and had lunch during the 4 hours .
The most difficult job was getting the fan bolts undone; think someone had put them in with something other than a 10mm spanner
With a 3.0 you do not have to disturb the Drive Belt (just in case someone asks).
The new pump from Roughtrax has a larger impeller, but that can only be a good think as it should move more water around the system.
Fingers crossed that’s stopped my water leak.
Thanks to TonyN for his guidance on how to do it.
