It could be the radiator, flushing them won't clear it properly if it's choked, it'll merely clear a path through it.
Gen 3 Temps & Cooling
Pumps rarely break, apart from seal leaking or bearing going.Originally posted by brett_mil View PostThanks again.
Would it be worth checking the water pump?
Also, would the new head have been damaged if it went to 100 on the test run?
100 isn't a problem under load or up hills, thats not even in the red zone, its about 3/4 hot on gauge on mine, but under the red bit.
Split your viscous fan hub, and put lots of 5-7000 or higher CST silicone oil in it, and give it another go.
If this dosn't fix it then think about a new rad, they get blocked easily, and you can't clean them withouty splitting it apart.4x4toys.co.uk - Keeping you on and off the road...
Is this the same stuff used in radio controlled cars?Originally posted by TonyN View PostSplit your viscous fan hub, and put lots of 5-7000 or higher CST silicone oil in it, and give it another go.
something like this?
http://www.teamxray.co.uk/productdet...07-showall.phphttp://www.thekentoffroadclub.co.uk
Mech has only now had the chance to get back on to working on her.
Says that the cambelt was loose even though he'd tightened it all up.
New tensioner and idler pulley on order.
Could this have caused the initial over heating that lead to the cracked head?http://www.thekentoffroadclub.co.uk
She's all sorted!
In the end I replaced the:
Head
Thermostat
Radiator
Water Pump
Viscous Fluid
Idler Pulley
Tensioner
My Bank manager has called to check if my card was stolen! But still worth it in the end! At least I know I have her all sorted out and I know the health of the cooling system!
Can't wait co go and collect and get offroad again!http://www.thekentoffroadclub.co.uk
