well now since we are talking 3rd gen cooling i would like to pick anyones brain (if it's possible on here)
any how my 3rd gen did a 24 mile run and the bottom of the rad was cold, i thought blockage so off came the rad back flushed the whole cooling system three times to make sure, i also put rad cleaner in the rad plus two kettle's of boiling water gave it a good swill around left it an hour to do it's work, anyway after i emptied the rad and flushed it from bottom to top and vice versa the water was clear anyway the main point is the rad was not blocked that i could see it's not any heavier than it should be either, so what are the chances of the stat being stuck shut? the problem being that it doesn't pressurise any more than it should and the rad temp by feel isn't over hot and i have no bubbling in the rad either so any other ideas?????
ps i think the stat change will be done tomorrow just in case
