Speedo wrong
  • Speedo wrong
    Speedo needle doesn't start reading until the truck is moving at a fair pace. I just put in a GPS so I thought I'd check various speeds to see how far it's out.
    Reads 30, is actually 36
    Reads 40, is actually 46
    Reads 50, is actually 57
    Not good as far as PC Plod is concerned!
    What's the diagnosis doctor?
    Got bigger wheels maybe ?
      What size tyres?
        They're 265 70 R16
          Then I'm guessing the needle was put back in the wrong position when the speedo face was changed.
            Could be someones taken the needle off, to fit a MPH dial perhaps, and not re fitted it in the right place.
              Thanks Vince
              Hey, I was going to come up to you at the end of January. Are you around in the next couple of weekends to give the truck a look over please?
              cheers!
                Originally posted by Surfboy View Post
                Thanks Vince
                cheers!
                Yes mate, this week-end would be better as the garage will be free. My drive is too steep to be checking things like fluid levels etc.
                  OK, this weekend is good. How do I contact you... I can't pm
                    I'd go with the needle like Vince said, if it was tyres/gearing, it would get progressively more out the faster you go.
                    It seems to be roughy 6mph out across the board, so just move the needle back 6 mph.
                      Thanks chaps! I'll have a go at moving the needle then.
                        E-mail: febsnowman@talktalk.net
                        Go to go back out now, will be in touch later.
