just a thought could one of the tumblers inside the barrel be stuck? it might be worth a dousing with wd40 or similar to try and free it just an idea...
Key won't turn
I've got to call bullshit on the blown brakelight stranding you, I went a week with my off side brakelight out end of January and had zero problems starting/driving my surf. Ok, I'll admit I shouldn't have left that long to replace but it never refused to start.
Originally posted by gbv2 View PostOk, I've just come back to this after thinking for a minute or two (ouch). If I'm out and say a brake light does go, would I be stranded? Should I be carrying spare bulbs and a socket set just incase?Do you know that, with a 50 character limit, it's
Originally posted by schrodingers-cat View PostSo your out in the back of beyond, your brakelight bulb blows and you aint got a spare so your fooked, Its one of those wind ups surelyDo you know that, with a 50 character limit, it's
Originally posted by Osborne View PostI've got to call bullshit on the blown brakelight stranding you, I went a week with my off side brakelight out end of January and had zero problems starting/driving my surf. Ok, I'll admit I shouldn't have left that long to replace but it never refused to start.
The brake light thing stops the gear stick from being released from the Park position.Do you know that, with a 50 character limit, it's
Originally posted by Albannach View PostIf one (or both) of the brake light lamps has blown, the gearstick interlock will not release the stick when you put your foot on the brake pedal.
Some say it's a 'safety' feature; I think it's a fault"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
Originally posted by yoshie View PostHowever this was not the fault with mine. Sill won't turn.Do you know that, with a 50 character limit, it's
Originally posted by Albannach View PostAs I said before, the interlock may be damaged or broken. Ordinarily, it will not release if there's a lamp blown.
Originally posted by Albannach View PostThe only thing that 'may' be an issue is the wee pawl thing that locks the key in the ignition when the truck is in gear. Disconnect the batteries (or unplug the wee connector on the ignition barrel), that will release the pawl.Brian
