hi everyone, do you have any idea whats up with my truck? (kzn130)
the surf has been stood for several months but now im ready to get it moving again.
connect the batteries and the surf fires up instantly, no problem at all, runs a little smoky but i hope a good run will clear any crap out of the pipes...
it will start again 2-3 times after first start then will not fire at all.
disconnect batts for 30 mins or so and will start again first few times and so on etc...
the only difference i can see is that when it is going to start the "engine Check" light is on until the engine is running then goes off. when its not going to start the check light is off.
i have ripped out all the Toad immobiliser etc as i originally thought this was part of the problem, but now i'm wondering if it might be the ECU.
i'm a bit stumped as i don't understand electrics much but has anyone experienced this before or got any ideas wherre to look?
and has anyone got a working ecu part no 89661 3D100 for sale? \i've been checking ebay and scrappies for ages!
thanks for any help!
