Hi, i own a 1994 3.0 L automatic surf which has recently developed a problem with its gear change.
It has started to over rev when changing gear, 1st to 2nd wont change up until it hits 3000 revs, 2nd to 3rd changes at 2750 ect.
it also doesn't seem to make any difference if i switch off the OD aswell.
I have done a search and it looks like its the ECU, what do you think ?
Also is there a gear box ECU or is it all done through the engine ECU ?, if this is the case.
Check the gear box level and it seem to be fine.
Any help would be great................
![Banghead](https://hiluxsurf.co.uk/core/images/smilies/banghead.gif)
Thanks.
Thanks.
