over the last few days my surf has developed a problem. its done 180k km.
always run fine. then i noticed sometimes when dropping the clutch when coming up to junctions etc to stop, the revs would drop slightly to low and cause the engine to shake a bit.
it was intermittant, and then one time it caused it to stall.
it has now got worse, and pretty much every time i depress the clutch it drops to barely enough revs to keep it alive, u can feel the steering go heavy due to the ps pump not rotating fast enough.
it is also starting to stall frequenty.
it has gone from being fine, to very quickly pretty bad, within 2 days, so i can only imagine within a day or so it will stall every time.
one other thing, is sometimes it recovers the revs and idles normally when it doesnt stall. other times it just stays idleing at about 200 revs shaking its ass off lol.
it also seems a bit jerky on and off the throttle when driving.
any help much appreacated, need this sorted asap.
thanks
nick
thanks
nick
