My 94 3ltr surf has just started blowing white smoke on start up.. I've read all the threads and it all sounds familier..
Basically all was fine with the surf untill the family and I spent a month in New Zealand (Surf sitting in an airport car park) We got back about a month ago.. But on first start up loads of white smoke, which went after driving for 2minutes.. I put this down to being stood and condensation in the exhaust.. It even sailed through an mot two weeks ago.
Over the past month there has been some white smoke in the mornings but wasn't much untill this past week. The thing that scares me is the smell. I thought first of all it was a burst pipe in the engine bay as there was that familier smell of hot coolant or coolant hitting an exhaust( a bit like burnt celary) Looked in the engine bay and no obvious leaks but the expansion tank was very low, about 1.5 ltrs. After I topped up the level the white smoke seems worst.... The temp gauge hasn't changed at all.. Oh yes I've just checked to see if there are in bubbles in the expansion tank and there are.
So what are the chances that It will only be the gasket.. I've only done about 200 miles in the past month since the symtoms first appeared...
I'm sure you experienced guys on here are sick off this topic, but any advice would be much appreciated.. I love my surf but if its going to be £1000+ish for a new head I don't know what I'm going to do..
