Well had a leak for a while now and if you read my last epic adventure into washing the oil off you would know it cost me dearly....
Well as i cannot see down the back of the motor and the body doesn't lift up like a drag car i borrowed a slim camera and took some lovely pictures.....
This is looking straight down the back of the head and as you can see the top of the bell housing is covered in oil.
This ruled out my first thought of main crank seal as how the hell would it get out the bottom of the bell housing and up onto the top.....?
This is shot across the back of the head and as you can see if the rocker was leaking surely the silver pipe would have its own oil coating ?
So my thought is if the head gasket was shot could it blow oil out the back and down ????
Or am i missing something else......
To top it all i know have a water leak from the flange on the other end of the silver pipe where it bolts to the block under the inlet manifold.....aaarrrgggghhhhh!! !!
May have to do a proper job and strip it off to find the oil leak and in the process fix the water leak.......
Paul1566
Paul1566
