Hi Guy's.
I need to pick your brains.
I have had probs with veggie feed and on Friday diesel feed (twin tank system) also.
So today I stripped out both filters the veggie one was OK but the diesel one was deffo clogged.
Changed both and then found out that the veggie problem was the pump not picking up.
Decided to take it for a run to slosh the veggie about and hope it picked up. The engine had been ticking over on diesel for about 20mins whilst trying to sort the veggie out.
Reversed out of the drive and was putting my belt on when the engine revs shot up to screaming, switching off did not stop the engine at first but it did stop eventually. Lots of black smoke.
I started it again with the same results top revs and not stopping.
Eventually it stopped.
But now it wont start at all. plenty of fuel to the injector pump, I did unscrew the No1 injector pipe and try to start it but there was only a slight trickle of fuel coming out.
Managed to flatten both batteries trying to start it.
Any idea's guy's I am confused as to why the rev's should shoot up with no foot on the gas.
Regards John
Regards John
