Just changed the engine over on my dads surf.
Started it and the engine has a knocking noise from under the rocker cover somewhere. The noise isn’t that noticeable at idle but progressively gets worse when the revs start building up until it completely disappears at over 3k ish.
Also the engine check light is lit up, I have printed off the self diagnostic info and will have a go at this tomorrow but was just wondering in the mean time if anyone had any idea of what this could be?
The injectors have been removed and bench tested somewhere and are all fine.
The fuel pressure regulator (think that’s what it is anyway) was bent so we changed that over and it seem to make a difference the first time it was re started but it is now back to the rattle.
There is a slight miss at around 3.5k constant rpm, there is also some white smoke when it misses.
Any help greatly appreciated.
Any experts in the South Lanarkshire area also?!
Dave
Dave
