Ok here goes. I have had a look through the forum and there have been a few cases of this but there has never been a post stating that there was a specific problem and how fixed.
The other day this just suddenly started happening when I started the Surf (3ltr TD, auto, kzn130 2nd gen).
It revs really high before changing gear and the top gear seems to have gone. It is like I am driving with ect and the OD buttons pressed in. But I assure you they aren't.
The revs are going up to 3500 rpm before changing into 2nd gear and almost as much up into 3rd. But then no 4th gear. It went back to normal the next day when I started her up but went to get more ATF anyway to do a flush and change.
The next day it has started doing it again even though I did change the atf. Anyone any ideas? I have checked the wires from transmission and even disconnected the battries for any hour to make sure the ECU was reset. Nothing helping so far.
and me, I seem to be resurecting old posts more than creating new ones! I have tried this, it didn't work not straight away anyway. Although the next day it had gone away only to come back the next day after that. Looking for a new ECU.
