Hi All,
I ordered pads and disks from a well known (on here) independent Hilux/Surf specialist that don't appear to be correct.
I have a 1995 Hilux Surf 3.0TD SSR-X Auto and the removed pads and disks are different to those supplied.
Does anybody know if there were any variances on the parts used for this model? Only one type of pad and disk is listed for the KZN130 on the specialist's website - but my local Motor Factor was able to supply the correct items after providing the VIN to them.
I also have some vibration from the front wheels (especially when braking), causes the steering to shake under braking and shimmy at about 50 to 60 MPH. This was with worn 50/50 All Terrain tyres (that the previous owner ran at 18psi) that may have contributed (new ones to be fitted).
Any help or guidance much appreciated.
Regards,
Andrew
KZN130 3.0TD SSR-X
Regards,
Andrew
KZN130 3.0TD SSR-X
