Idiot of the week anyone. Just left hospital and couldn start surf. Checked and the pos terminal on the batt was loose. Tightened it up which solved the problem but whilst doing it slipped and touched the socket wrench to the top left of the rad for a split second which has burnt a tiny hole in the rad! Revved the engine and sure enough coolant sprayed out. Damn it! Is there anything i can do or do i have to get recovered and then a new rad? Sending this from hospital from my mobile so hopefully it will work! Help!
